I just bought this car and all of a sudden the O/D off lite is on and it wont go into overdrive I have never seen an O/D switch so how do I get the car to go back to normal and have the overdrive engage on the freeway?
The O/D main switch contacts go off when the switch is pushed in and come on when it is pushed out. In O/D main switch OFF position, the O/D OFF indicator lights up, and the ECM prohibits shifting to overdrive. The ECM also causes the O/D OFF indicator light to blink when a malfunction is detected. In this case, connecting the OBD II scan tool or LEXUS hand–held tester to the DLC3 can display the diagnostic trouble code.
