Home » Car Questions » 1994 Dodge Grand Caravan
Recently my rear defrost stopped working. Then I noticed the the rear heater fan also did not work. I then noticed a little while later that I had no reverse lights and no brake lights. Can someone please tell me how to fix this. Thanks
1 thought on “1994 Dodge Grand Caravan”
  1. Here is the defroster diagram. looks like only 2 fuses and 1 relay. The lower fuse in the diagram goes to the heated mirrors if equipped.
    The rear blower motor also uses FUSE #20
    And you probably guessed it, FUSE #20 for the back up lights….
    I recommend starting with fuse #20
    Defroster wiring diagram
