why does my car not start I was driving and the car cut off Hickory pack up and come off again this happened a couple times now it doesn’t start it turns over but it won’t start. I am NOT getting a spark from the plugs what do I need to do and how to do it the cheapest way?
You will want to look to see if you are not getting spark and injector pulse.
If you are not getting both, your computer may need to be flashed. Your Crank Position Sensor may need to be replaced and or your computer replaced.
Does it have a check engine light on when it does run? What are the codes?
The codes may help point to a failed system sensor or sub-system. Post back in the comments below and we will figure this one out.
