Home » Car Questions » 2008 cadillac DTS
2008 cadillac DTS
how do you change head light blubs
1 thought on “2008 cadillac DTS”
  1. Cadillac headlight bulb diagram
    Caution: The high intensity discharge system produces high voltage and current. In order to reduce the risk of severe shocks and burns, the battery negative cable must be disconnected any time service work is being performed on or around the high intensity discharge system.
    Caution: The high intensity discharge system produces high voltage and current. To reduce the risk of severe shocks and burns:
    • Never open the high intensity discharge system ballast or the arc tube assembly starter.
    • Never probe between the high intensity discharge system ballast output connector and the arc tube assembly.
    Preliminary Procedure
    Remove the headlamp.
    1 Headlamp Bulb Cover Screw (Qty: 3)
    Tip
    Do not remove the front bumper fascia to perform this procedure. Just remove enough fasteners and retainers in order to lower one corner of the bumper fascia to access the bulb.
    Tighten 3 N·m (27 lb in)
    2 Headlamp Bulb Cover
    3 Headlamp Bulb Retention Spring (Qty: 2)
    Tip
    Release the springs in order to access the high intensity discharge (HID) bulb.
    4 Headlamp Bulb Electrical Connector
    Tip
    Pull the bulb rearward and release the electrical connector from the bulb.
    5 Headlamp Bulb
    Tip
    Pull the headlamp bulb from the headlamp assembly
