Home » Car Questions » ford escort 2001
ford escort 2001
codes only go up to 0900 something and my code reads 1131
1 thought on “ford escort 2001”
  1. P1131 Lack Of HO2S11 Switch – Sensor Indicates Lean
    Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Lean Bank 1
    Reference Link:
    http://www.freeautomechanic.com/diagnostictroblecodes.html
    Possible causes
    – Faulty Oxygen Sensor
    – Vacuum leak affecting bank 1 only
    – Fuel injector problem bank 1
    – Check for cylinder misfire on bank 1
    – Engine mechanical condition
    Tech notes
    Though the Oxygen (O2) sensor, the Engine Control Module (ECM) has detected a lean system, which means that there is either not enough fuel or and excessive amount of air in the system. Start by checking for vacuum leaks.
    A Heated Exhaust Oxygen (HO2S) sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
