Home » Car Questions » 1995 ford f150 5.0 302 4×4
There is a brake line part that is mounted on my rear axle driver side where a hard rubber tube connects and it splits to the two rear brakes and has what seems like a vent hose opposite of the main rubber line. I hope this is enough description I cannot upload the pic .
what is this part called it is stripped and need to find a new one. Thanks
1 thought on “1995 ford f150 5.0 302 4×4”
  1. Brake Proportioning Valve. or Height Sensing Proportioning Valve. These would be the only two things that might be close to what I think you are trying to describe.
