There is a brake line part that is mounted on my rear axle driver side where a hard rubber tube connects and it splits to the two rear brakes and has what seems like a vent hose opposite of the main rubber line. I hope this is enough description I cannot upload the pic .
what is this part called it is stripped and need to find a new one. Thanks
Brake Proportioning Valve. or Height Sensing Proportioning Valve. These would be the only two things that might be close to what I think you are trying to describe.
