i tried to put led dash lights in and now i have no dash lights and none of my gauges work. i put in all new fuses and still nothing.
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
View Comments
Only replace a fuse if it is blown. Check For power going to the fuse, you may have blown a fusable link from the battery and no power is even getting to the fuse panel itself. Check for power on both sides of the dash light fuse. Then check for power at the light switch. got power there, check for power at the dash lights, if that checks out, go back and check your grounds. Make sure you didn't unplug anything while trying to install your LED's.
