I replaced the valve cover gasket went to start and it turns over but will not start, I have since replaced spark plugs and wires distributor cap crankshaft sensor coil and right now the throttle cable still nothing its getting spark and gas yet the only way i can get it to start is to spray either into it.
If it will run on starting fluid then you are half way there. You now know the spark, compression and timing are all good. You also know that the issue is somewhere in the fuel system. Next step would be to check the fuel pressure to see if the fuel filter is clogged, the fuel pump is bad or you bent a fuel line the last time you when 4-wheeling, if you do that sort of thing with it.
