Home » Car Questions » 2005 Lincoln LS V8
2005 Lincoln LS V8
Lincoln LS V8 3.9L engine
The air conditioner is not working, tried Freon and it did not fix the problem. Under the hood there is no 10 amp fuse box, is this the problem? If I put a 10 amp fuse in will the a/c work? The number fuse in the box is 15 and the number fuse position is 1
1 thought on “2005 Lincoln LS V8”
