Home » Car Questions » 2011 Ford Escape Hybrid Limited
Clunking noises when starting and stopping from front of car. Seems to be chassis or suspension related. Could it possibly be loose mounting bolts? Does not happen if starting and stopping very slowly.
1 thought on “2011 Ford Escape Hybrid Limited”
  1. Most likely could be loose brake caliper mounting bolts as it is old enough to have had some brake work done but not so old that the suspension should be worn out as of yet. If it has had any recent work done, I would look there first.
    Best thing to do would be to eliminate and simplify. Here is a great article that should help you with that:
    Troubleshooting Auto Repair Noises
