Home » Car Questions » 1994 Infiniti J30
1994 Infiniti J30
When I reconnect the battery, the trunk opens and the front lights come on and the rear marking lights come on and will not turn off.  How can turn these off or do I have to pull the fuse for the security system?  I would also need a fuse diagram, the owner did not have the manual when I purchased the vehicle.
1 thought on “1994 Infiniti J30”
  1. After taking a quick look at the wiring diagram for the exterior lighting it would appear that there is a Tail Light Relay. Most likely the relay is sticking on. Start by just unplugging the relay and see if the lights stay off. If so, just replace it with a new one.
    Infiniti J30 Wiring Diagram
