Home » Car Questions » 1995 Honda Accord LX 2.2 V Tech
I had a blown head gasket from fans going out and got it replaced with new head water pump and all seals and gaskets. Car ran fine one day and the next it wouldn’t fire so I replaced distributor. Car started back firing and its getting gas but wont crank. What’s the problem to this issue?
1 thought on “1995 Honda Accord LX 2.2 V Tech”
  1. Sounds like the timing is off. General rule of thumb for any back fire. Timing is off. Double check your distributor is tight and not loose. Then you will need to check your timing marks.
