After I got in my car accident my suspension strut is bent & my driver wheel goes in & outward while I drive & continues when it rotates. I know my suspension strut is bent as well but im not sure what else is bent that rotates. I know its not my rim thanks very much if you can answer my question I have a lil daughter & I dont want to put her at risk in my car till I find out whats wrong ? Thank you
My driver wheel goes inward when the wheel rotes after I got in my car accident I know my suspension strut is bent but I know there’s something els with the wheel & it also eats the inside of my tire. So my wheel goes in & outward when I drive it & eats my tire up pretty fast.
Possible bad hub bearing or any other component like ball joints or the control arms themselves.
Wheel Hub & Bearing, Replace
Front
- Raise and support front of vehicle, then remove front tire and wheel assembly.
- Remove brake hose bracket mounting bolts.
- Remove bracket mounting bolts and support caliper aside.
- Raise locking tab and remove spindle nut, Fig. 1.
- Push disk off hub using two 12 mm bolts Turn each bolt two turns at time.
- Remove mounting bolts and wheel sensor. Do not disconnect sensor connector.
- Remove nut while holding joint pin with suitable hex wrench and disconnect stabilizer link from lower arm.
- Remove lock pin and lower arm ball joint, castle nut.
- Disconnect lower arm from knuckle using suitable ball joint remover tool.
- Loosen strut pinch bolts while holding nuts, then remove bolts and nuts.
- Remove driveshaft outboard joint from knuckle by tapping driveshaft end with suitable plastic hammer while pulling knuckle outward. Do not pull driveshaft end outward.
- Remove knuckle.
- Remove hub from steering knuckle using suitable press.
- Press wheel bearing inner race out of hub suitable bearing separator and press.
- Remove snap ring and splash guard.
- Press wheel bearing out of knuckle using suitable adapters and press.
- Reverse procedure to install. Tighten all bolts and nuts to specifications.
