Home » Car Questions » 2005 mercury sable2005 mercury sableJuly 7, 2014Left rear brake light not working, all other lights working corectly.Keywords:Brake Lightleft rear brake light problem.LightsSable1 thought on “2005 mercury sable” Freeautomechanic July 7, 2014 at 8:13 pm My first thought would be replace the light bulb. Try swapping it with the other side and see if the issue follows the bulb…. get a new bulb. Check for power and ground at the plug and trace backward if it is not there and correct the wiring.Comments are closed.previous07 Pontiac g5 gtnextford fiesta 1.4 2006
