When my Headlights are on, If I turn my Hazardous lights or turn signals on at the same time as my Headlights, my Headlights quit working! So could you please tell me what the problem is and how to fix it?
My first guess would be bad/loose/corroded/rusted Ground connections. Second guess would be the head light switch. it would seem as though a bad ground would allow the turn signals/hazzards to back feed the headlights.
You could check reference voltages and post them. Also you could use a multi-meter to check voltage resistance in the wiring.
Reference Guide: http://www.freeautomechanic.com/turn-signal.pdf
