Home » Car Questions » 2001 chrysler sebring
Car sometimes overheats after driving for 1.5 hours. I’m thinking water pump or thermostat. Am I correct, or am I overlooking something?
2 thoughts on “2001 chrysler sebring”
  1. First thing to check would be the coolant level. If it is low, pressure test the cooling system and repair any leaks present. Top off the level and retest.
    It is possible the thermostat is sticking open. It is also possible that the fan is not coming on.(bad fan or relays, wiring, etc.)
    let us know what you find and post it back in the comments below.
