My ABS light came on. The truck hasn’t been driven in over a week. I changed the transmission shift position sensor which was faulty and both batteries. This light has never come on and stayed on.
The ABS light when on and stays on when there is an issue in the system. A scan tool is used to pull the ABS codes from the system. Once you have the codes you can post them back here and we can help you with those.
In most cases it will turn out to be a wheel speed sensor or a connection at one of the speed sensors.
The good news is as long as the ABS light is on the system will not function at all so no further damage will occur. You can drive it this way for as long as you need until you are able to get it into the shop or look at it yourself.
Reference: ABS Troubleshooting
