Will start and idle but has a miss will run for a while but it dies and will not restart can’t press the throttle it dies why please help
Keywords:Sante Fe
First things first, if the check engine light is on we will need the codes to help guide you in the right direction. Autozone will pull the codes for free. Just post the codes below in the comments and we will assist you further.
Sounds like it may be a failing coil or a loose hose connection at the throttle body.
