My car windows are the problem. I can get the back windows to role down and up using that doors button. I can not get the back windows to role down from the drivers door but if i role them down from the back i can use the drivers door panel to role them up. when i try to role them down from the drivers door it sounds like its trying but it doesn’t budge.
2005 hyundai Elantra
There are three possibilities that come to mind for this issue.
1. The Drivers Door Master Switch
2. The Wiring from the Drivers Door Master Switch
3. The Connections
I would use a multi-meter and trace the wiring starting at the Drivers Door Master Switch. Check for power coming from the master switch heading to the door with the issue. If no power, replace the master switch. If you have power coming from trace going back and repair as needed.
