With battery fully charged my 1996 Honda accord turns on but when i turn the lights on there is a ticking sound under the glove box. I turn off the car and when turning it right back on the battery is drained the lights go dim and it will not start.
Most likely cause for the issue you are having would be the the Battery. Install a new battery and your problem should be gone. If you notice a battery indicator light on the dash then check the alternator as well.
