Hi
Thanks you for the opportunity to submit my question and thank you for helping me. My Getz don’t wanna start. I have to kick start it the whole time. I changed the battery but the same problem occurs, as soon as the car is switched off it doesn’t start. I have an error P1130
Kind regards
Chris
P1130 Hyundai – Start Solenoid- Malfunction
Sounds like it is time to replace the STARTER assembly. You can test for battery positive at the “S” terminal on the starter solenoid while someone holds the key in the the “START” position the next time it won’t start. If you see battery positive, replace the starter assembly. If you do not see battery positive at the “S” terminal on the starter solenoid then you will need to trace backward from there.
