Home » Car Questions » 2007 Mustang GT – manual
It will not go into gear. The clutch pedal felt like it had a weird give when I pushed it in to shift, then it could shift no more. So now it’s stuck in neutral. There’s still tension in the pedal
1 thought on “2007 Mustang GT – manual”
  1. See if it will work with the engine off. If not, you may have internal transmission problems. If it does, then you are probably in need of a new clutch master and slave cylinder. Check the Hydraulic clutch fluid level, if it is low then you are going to need a new clutch assembly also.
    If you need the repair procedures for this repair, follow the auto repair manuals tab to your left in the navigation bar.
