Pins bad on existing wiring harness for fuel system control module near the spare tire. I have another harness off another 2008 truck same make and model. Pins on the new harness are not located in the same place as the existing module. Conductor amount and color are correct just located in different positions within the actual connection point on the module itself. I know gm has to reprogram the module anyway so can I just cut back existing harness, splice in the new harness and have it reprogrammed or do the female ends have to line up with the existing ends on the existing module that is mounted above spare tire?
Chevy silverado, 2007/08 5.3 litre Vin J
Keywords:silverado
the connector pins must line up with the harness connector pins. The wire color doesn’t matter so much as you can splice the wires to what ever color you want but the pins have to line up in order to complete the circuit.
