from one month i found that sometimes when the car move with speed over 90 km/hr, it stop respond with Press on the accelerator and calm the speed of the car and if i continue pressure get smell of raw gasoline and end this problem if i raise my feet from the gas pedal for Seconds
Keywords:Nubria
It may be that the tps sensor is out of adjustment and needs to be tested.
Are there any check engine light codes?
No, there is no check engine light codes, i check the TPS sensors it is working good.
The smell of raw gasoline would indicate a fuel leak or un burned fuel. I would think maybe one of your spark plugs may be fouled. This would be the next thing I would look at. Remove all the spark plugs and take note to color and dampness.
Spark Plug Burn Chart
If you see one that is oil fouled or fuel fouled, this is the cylinder to concentrate on.
