I have a 1998 mitsubishi eclipse, manual transmission, that won’t go into reverse, second or fourth gear, what can be the problem?
Keywords:eclipse
If you can shift gears OK when the engine is turned off then your transmission is GOOD. However, your next thing to check would be the hydraulic clutch fluid level. If it is low, then it is time to replace the clutch disc assembly. If the fluid level is not low, then it is time to replace the clutch master and slave cylinders.
