I purchased this vehicle from a buy here pay here 5 weeks ago. Two days ago I pulled into the driveway and turned my car off after it had been running fine. Ten minutes later I started it and it won’t move! No reverse, forward, or anything. Will shift though and the Shifter cables or whatever are pulling and seem to be working fine. Whats wrong???
My first thought would be, did you leave the park brake on? Is the engine running fine? Is there a check engine light illuminated on the dash?
It is possible that the neutral safety switch/gear selector switch is going bad or loose connection..
