I was driving the truck, hit a bump and the engine just stopped. All the other electrical works fine. Fuses are good. I have no spark so I replaced the coil and still nothing. At a Loss
Well the first thing I notice is the engine is a different size than what came in it. But No matter.
360ci engine 1973 – 1979 F-100 & Larger F-Series Trucks.
Does this engine have points style distributor or HEI style? Check your points gap and cap and wires. If your not getting any spark out of coil to the distributor and you do have correct voltage, you may need to look at the points or pick up coil depending on what set up you have.
