Intermitant problem (sometimes and somtimes not) with transmission not shifting since the car was purchased. Will lock in lower gear and no matter the speed traveling transmission will not allow shifting into higher gears. Transmission was replaced once. Same problem occurs. Car only has 63 thousand miles. Not high milage. Input output sensor has been changed. Electronic brain has been changed.
Keywords:Sebring
First thing i would do would be to have the computer scanned for codes. This can be an effective way to learn if there has been anything recorded. Seems your local auto parts dealer may offer this for free. Post the codes you find below in the comments.
