My MOT certificate states that there is a play in the rear upper bushes (prefix I know nothing about cars) i took it to a local mechanic who stated i require a whole right side wish bone, but i’m not sure as it only states an issue with the bushes, is this a simple fix or does it require a whole wishbone? (bear in mind it passed with the ‘play’ being an observation). Appreciate any assistance.
In most cases the wishbone comes with the new Bushings installed already and is the only way to get the bushings. Having the bushings replaced separately would require more time for your money and less parts(if available). So that would mean replacing the entire wishbone would give you more part and less labor for the same money. Let me know if this doesn’t make sense.
