steering fluid leaks under the radiator / front bumper, well empties in 3 days.
tried stop leaks 16 ozs. no luck . leak is the same.
You will need to clean off all effected areas of all fluid. Fill the steering fluid. Have someone start the engine a d move steering wheel slowly back and forth while you look for the leak. If it is leaking from a pressure hose it will be seen spraying out of the leak. A good idea to take precautions accordingly. If the leak is from a none pressure hose, it will just ooze out and downward. UN-pressurized leaks do not leak up hill.
Once you locate the leak, repair/replace as needed. If you need further guidance, post back below or follow the auto repair manuals tab
