Home » Car Questions » 1997 mitsubishi rvr sports gear1997 mitsubishi rvr sports gearDecember 31, 2014on acceleration it sputters until it gets up to 2000 revs and then runs fine what can be happening?Keywords:accelertionRVRsputtering1 thought on “1997 mitsubishi rvr sports gear” Freeautomechanic January 1, 2015 at 12:35 pm First off, if the check engine light is on it would serve us both to extract the codes and post them.This could be from several things, Has there been any recent work or modifications done?Possible tune up needed, vacuum leak, clogged fuel injectors, TPS sensor going out, coil going bad, ignition control module, MAF sensor, bad gas…Engine SensorsComments are closed.previous2000 Dodge Stratusnext2003 Mini Cooper S
Engine Sensors
