Home » Car Questions » 1997 mitsubishi rvr sports gear
on acceleration it sputters until it gets up to 2000 revs and then runs fine what can be happening?
1 thought on “1997 mitsubishi rvr sports gear”
  1. First off, if the check engine light is on it would serve us both to extract the codes and post them.
    This could be from several things, Has there been any recent work or modifications done?
    Possible tune up needed, vacuum leak, clogged fuel injectors, TPS sensor going out, coil going bad, ignition control module, MAF sensor, bad gas…
    Engine Sensors
