Home » Car Questions » 1999GMC Jimmy1999GMC JimmyDecember 27, 2014wont start, turns over but wont start, took spark plug out and its wet with gasKeywords:Jimmywont start1 thought on “1999GMC Jimmy” Freeautomechanic December 30, 2014 at 10:09 am You will need to check for spark and injector pulse.If you are missing both, check the ECM fuse first. If you have a weak spark and injector pulse, you may just need a tune up(most common)No Start DiagnosticsLet me know what you find.Comments are closed.previous1995 mitsubishi rvr 2litre non turbonextGti Golf VW 2002
