Home » Car Questions » 2005 hyundia tuscon
2005 hyundia tuscon
After jumpstarting my vehicle my windows, parting lights and keyless entry quit working what would cause this. Check all the fuses and found nothing wrong
1 thought on “2005 hyundia tuscon”
  1. This vehicle is equipped with “Fusible Links” coming from the battery. These are inline fuses attached directly to the wires coming from the battery.
    The Power Windows is a 50Amp fusible link. This one is located inside the E/R Fuse & Relay Box.
    No surprise after checking the parking brake wiring diagram to see the same 50 Amp Fusible Link provide power to the exterior lighting.
    This is where to start, Replace the 50 amp Fuse. It will look larger in size then the regular fuses you are used to looking at.
