I am having back fire issues when I accelerate it seems real sluggish then when you get on it it goes over the top is possible ground issue or throttle regulator or something else. Also having back fire issues when I accelerate its real sluggish until you push on the gas hard.
Keywords:Ranger
Since this is a pre-1996 Ford you have the ability to pull your check engine light codes yourself. This would be the first step in diagnosing the problem.
How to Extract Ford Engine Codes Yourself
Post your findings in the comments below.
