where is the oil pressure senser on 3.0 V6 ? How difficult is it to get a manual gauge to check pressure ?
04 toyota sieanna
Keywords:Sienna
Oil pressure switch is located on the front of the engine behind the serpentine belt.
![toyota sienna oil pressure switch location diagram](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNzQiIGhlaWdodD0iMTk5IiB2aWV3Qm94PSIwIDAgMjc0IDE5OSI+PHJlY3Qgd2lkdGg9IjEwMCUiIGhlaWdodD0iMTAwJSIgZmlsbD0iI2NmZDRkYiIvPjwvc3ZnPg==)
You can purchase a new sending unit for less than $15.00 So if you are going to go through the trouble of taking the old one out, I recommend installing a new one. This will save you time and money.
Use a 27mm deep socket wrench to remove the oil pressure switch
