Home » Car Questions » 1994 Dodge Ram 1500 4×2
truck is a base model with a 2″ suspension lift kit installed. Need to replace the rear shocks but not sure what size or type.
2 thoughts on “1994 Dodge Ram 1500 4×2”
  1. Since you have a 2″ suspension lift kit you will need to install aftermarket shocks that work with the 2″ suspension lift. Stock shocks will NOT work for this application. You an go with the same style that are on the truck now or choose form any of the aftermarket shocks available for your truck with a 2″ suspension lift.
    You can get these for the rear for under $90.00 ea.
  2. Replacement front shock absorber
  3. 2 inches over stock length
  4. Twin tube design
  5. Velocity sensitive valving
  6. Scorpion performance shock absorber
  7. Double check at the top for correct engine size, 4×4, etc to make certain they fit your specific vehicle.
    Many 2″ suspension lift kits only lift the front 2 ” and not the rear, if this is the case, stock shocks should fit on the rear.
