Home » Car Questions » 1994 handye alantra1994 handye alantraJanuary 24, 2015why does the car and the steering wheel shake when I drive?Keywords:elantrathe tire pressure and steering fluid are ok.1 thought on “1994 handye alantra” Freeautomechanic January 26, 2015 at 9:31 am This would, in most cases, be related to the tires. A vibration that comes and goes at certain speeds is most commonly caused by wheel/tire balancing.A continuous vibration is generally caused by a busted belt in the tire.If the vibration is felt when applying the brake, this is generally caused from warped brake rotors.Comments are closed.previous1999 Chevy Silverado 5.3next1997 isuzu trooper
