Home » Car Questions » 1997 Subaru impreza 2 door coupe1997 Subaru impreza 2 door coupeJanuary 17, 2015I replaced the water pump on the car found the passenger side head loose, can a new timing belt be put on?Keywords:Imprezatiming beltWater Pump1 thought on “1997 Subaru impreza 2 door coupe” Freeautomechanic January 17, 2015 at 1:38 pm can a new timing belt be put on? I think I would since it drives the water pump. it would seem like the best time to replace it seeing as you have to remove the timing belt to replace the water pump.Comments are closed.previous2004 Mercury Sable GSnext2wd 1995 blazer
