Hit ditch burned up clutch trying to get it. Was told I had to replace entire trans because it all wheel drive. Is this true? Any help would be great….
If this is a standard shift transmission and the only thing that is wrong is the clutch, then you only need to replace the clutch.
whoever told you this are blowing smoke up your #$@!
Labor time is 5.4 hours.
CLUTCH REPLACEMENT PROCEDURE
To Remove:
1.Remove the transmission.
2.Install a flywheel locking tool.
3.Remove the pressure plate mounting bolts from the flywheel.
4.Remove the pressure plate and clutch disc.
To Install:
1.Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing.
2.Install the pressure plate on the flywheel with a gap of 120� or more between the “0” balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
3.Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
4.Remove the clutch disc alignment tool.
5.Install the transmission.
