Home » Car Questions » renault master
renault master
small light won’t turn off in back. it is a small light near the floor, next to the slidding door in the back.
useully it comes on when i open the door and turns off when i shut the door. Now it just stays on.
i dont really need it. is there someway to disable it!?
1 thought on “renault master”
  1. The easiest way to disable a light is to remove the bulb.
    The reason the light stays on is the door latch switch assembly needs to be replaced(common failure part). Or just remove the bulb, however you wanna handle it.
