Home » Car Questions » 01Chrysler sebering lxi with 3.0
I pulled the car in. it did start and run but stalled while accelerating. now it won’t crank. It fires gets gas. I changed crank sensor, it cranked and run like a new car then died. tried to crank again and it doesnt start. What else could be my problem?
1 thought on “01Chrysler sebering lxi with 3.0”
  1. Check for injector pulse and fire, if you are missing both. Check fuses first. Then recheck crank sensor and Sensor wiring. If that checks out… Replace the ECM.
    Missing just spark… test/replace ignition control module.
    Got spark… see if it will run on starting fluid, if it does.. concentrate of the fuel system. Check fuel pressure and then check for injector pulse.
    No Start Troubleshooting
