I have been replacing batterys and starters and alternators for the past month, i do not know whats up with it
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
View Comments
Why are you replacing them to begin with?
If you are installing reman parts it may be that the parts are no good. I have seen this quite often. One of the worst I have used is A1 Cardone parts and any electrical component with moving parts form Autozone. They are cheap and they will warranty the part, but no the labor... there is a reason for that as they know the parts aren't all that good to begin with. My opinion after 20 years of working on cars.
