Home » Car Questions » 1997 ford ranger
1997 ford ranger
How to replace door windows
1 thought on “1997 ford ranger”
  1. TIP: I use these to hold glass up in place while I unbolt and bolt brackets, etc. Real Time saver and allows you to do the job without help form your buddies.
    Lisle 63900 Window Holder: Click on image for more details
    Door Window Glass, Ranger
    Removal
    1.Remove front door trim panel (23942) and front door trim shield (237A04).
    2.Raise front door window glass (21410) to full up position.
    3.Remove rear glass run retainer from front door (20124).
    4.Lower front door window glass to gain access to front door window channel bracket and glass retention rivets.
    5.NOTE: Use care when drilling not to damage glass bracket and spacer/retainers.
    Remove center pin from the glass retention rivets using a drift punch. Then, use a 6.35mm (1/4-inch) diameter drill and drill out each rivet.
    6.Remove the front door window glass through the door window opening.
    Installation
    1.Install spacer and retainer into glass retention holes.
    2.Install front door window glass into front door through the door window opening.
    3.Position the front door window glass to the front door window channel bracket and align with the retaining holes.
    4.Install retaining rivets.
    5.Raise front door window glass to full up position.
    6.Install the rear glass run retainer.
    7.Cycle front door window glass up and down to check operation.
    8.Install front door trim shield and front door trim panel.
    1997 Ford Ranger Front Door Glass Removal Diagram
