Home » Car Questions » 1998 Honda civic
1998 Honda civic
My friend..a mechanic cleaned the spark plugs..distributer cap and rotor button..it ran for a few minutes and died.. it turns over but won’t start…could it just need to have new plugs.plug wires..distributed cap and button replaced or what else could cause this problem
1 thought on “1998 Honda civic”
  1. It is possible, most certainly.
    First I would confirm if it has spark at the spark plugs.
    If you have spark, try spraying starting fluid in the air filter. If it will run on starting fluid, you may have a fuel related issue and not a spark issue.
    Let us know what you find.
    No Start Diagnostics
