Home » Car Questions » 2000 Dodge Intrepid
2000 Dodge Intrepid
How do I change the bulbs in the map light console.
1 thought on “2000 Dodge Intrepid”
  1. MAP LAMP – removal and installation
    REMOVAL
    1.Open hood, disconnect and isolate the negative battery cable remote terminal from the remote battery post .
    2.Remove overhead console, refer to Console Removal and Installation procedures below
    3.Remove lamp socket from mounting.
    4.Remove lamp(s). Replace as necessary.
    INSTALLATION
    For installation, reverse the above procedures.
    MINI CONSOLE – removal and installation
    REMOVAL
    1.Remove screw from windshield side of console.
    2.Grasp the front of console and pull downward to disconnect the retaining clips.
    3.Disconnect wire connectors and lower the console.
    INSTALLATION
