My manual transmission is stuck in 3rd gear pretty sure it’s not a linkage problem. Is it going to require removal to fix. If not what is the fix
Keywords:Bettle
Firest thing to do would be to disconnect the linkage from the transmission and see if the shifter will move. If it does, you know the transmission has to come out to be repaired. If it doesn’t, your problem isn’t in the transmission.
