Couple of different ways to approach this. You can repair the drain hole by re-threading it and installing a new Drain plug. Here is the kit you need for that. (Best Option) Click on Image for more Details…
Or, you can install a Rubber fix-all drain plug. When you tighten it down it expands and seals…
