Home » Car Questions » 2009 toyota corolla 1.6
My car showed battery warning while I was driving I stopped and check to see water pump was leaking I poured more water and drive more 5 minutes since I wasn’t far from home, I changed the water pump refill the coolant and when I tried to start the car it was cranking but not starting the biggest problem now is abs,battery, engine lights are on and the battery is completely low it doesn’t crank it just does the trtrtrtrtr sound
1 thought on “2009 toyota corolla 1.6”
